Re: I can't see the date/hour of the posts!
The problem is definitely caused by an adblocker. The class the date and time header is in, got added to some adblock rule. Usually those rules update periodically automatically. This explains why one would see it first in one browser and not yet in another, but then the problem also shows up in the other browser, after the rules updated automatically.
The problem is likely caused by the "EasyList" in your adblocker. It now includes a filter for "###theAd". wings900 forum software refers to the line that includes the date and time of the post with the class "thead", so the filter creates a false positive for theAd.
Possible solutions are:
1. deactivate Adblock altogether – very bad
2. deactivate the "EasyList" in your subscribed filters – not great, but might not change much, depending on how many and which other list you subscribe to
3. deactivate Adblock on wings900
4. the best solution is: add the following rule to your Adblock rules:
[CODE]wings900.com#@#.theAd[/CODE]
After you do that, the date and time line returns.
Since this error also effects some other sites/forums, you might opt to add the rule
[CODE]#@#.theAd[/CODE]
instead, Or create multiple rules for sites affected, that you visit like
Thanks,
Marie, Community Support
