Originally Posted by Flight fan
Here they are:
The damage can be seen in the upper portion of the pictures.
Look at the secong picture, interior of the cockpit get yellow, due to much too much glue you have used to assemble both parts of the fuselage. Unfortunately there are only two ways to repair it, both very drastic:
First way is to buy a new model and use much better adhesive, e.g.: UHU Sekundenkleber (best in mini tubes 2ml) with special tools for application (stainless steel aplicators;
Second way depend of your skills... You can use epoxy putty and try to get the shape of thge fuselage back. It is hard and long way...
Personaly, I suggest first way. Is much simple. On damaged model you can train glue application, and some parts could be spare elements for second kit.
Regarding glues/adhesives:
Remember that all product based on acethone solvent are
very very agresive to plastic model kits.
Acethone is dissolving plastic material (mostly styrene or ABS) and drying by vaporation of the solvent (acethone) confirming bonding of "melted" parts.
It is much better to use cyanoacrylate adhesives, due to easy removal of them by using debonders. Moisture speed up bonding process !!!
With this kind of adhesives (cyanoacrylates) you shall be very careful, due to extremly short bonding time.
DO NOT TOUCH ANYTHING WHEN YOUR FINGERS/HANDS ARE WET WITH ADHESIVE.
Let the bonder dry and than gently remove it from hands/fingers.
