Go Back   Wings900 Discussion Forums > Wings900 Model Terminal > Model Airports
Old 04-15-2010, 02:41 AM   #1
alabatusa's Avatar
alabatusa is getting startedalabatusa is getting startedalabatusa is getting startedalabatusa is getting startedalabatusa is getting startedalabatusa is getting started
Thumbs up [project] Allama Iqbal International Airport - Lahore Model
Hi Everyone,
Im new to model Airport building but it's been something i've wanted to do for a while.
My Project is to rebuild a model of Allama Iqbal International Airport Lahore - Pakistan. As shown below
I couldn't find plans for it anywhere, so i stole some from my friend "google earth". Below:
I have bought a Gemni Jets terminal and ground foil from hobbyco, Sydney ( i live in australia) for $475, $325 for terminal and $150 for the foil. Now i know what you guys are gonna say. The Gemni jet terminal looks nothing like AIIA as above. Thing is i didnt plan on modelling AIIA. But after i bought it i was sorta put of by the fact that the terminal sits in the middle and there's no roads coming to the terminal. There's a skytrain on the roof but it connects to nothing. To me im like how do people get to the damn airport.so i've decided not to go with their design. I got some inspiration from airport diorama design website and wat they did with the gemni terminal and put a facade up the front. But instead of buying theirs i wanna build a higher quality terminal front myself. As i realise the back part of the terminal is pretty close to the design they have at AIIA.
As for the Foil, i think i have wasted that $150, and i might go with the airport diaorama desgins custom airport kit and design my own similar to the snapshot from google earth.
I've already got heaps of planes, a control tower. also got about 500 LED's at home. a few grain bulbs to make some flood lights (currently looking for some sort of mirror stickers to reflect light).
So hopefully with help from you guys i can do this. I know i'm probably gonna use balsa wood to make the front end model. Probably gonna need tips along the way.
Also i need a base. Im thinking plywood. Model will be approximately 3.5-4 m by 2m. Any idea's on what thickness would be good? remembering im going to have to put through led's on this. And idea's on the best way to suppourt the ply wood? I.e teach me how to create a table.
Thanks guys
Hope we can pull this through.
Atif
alabatusa is offline   Reply With Quote
Old 04-18-2010, 09:38 AM   #2
Peak Airways's Avatar
Peak Airways is a good contributorPeak Airways is a good contributorPeak Airways is a good contributorPeak Airways is a good contributorPeak Airways is a good contributorPeak Airways is a good contributorPeak Airways is a good contributorPeak Airways is a good contributorPeak Airways is a good contributor
Re: [project] Allama Iqbal International Airport - Lahore Model
Good luck, would love to see how this works out. Plywood works OK, however it's not ideal for painting or for adhering cardstock to it. I would recommend either styrofoam insulation panels or MDF.
Peak Airways is offline   Reply With Quote
Old 04-18-2010, 12:53 PM   #3
ATC Graduate
SouthwestAirlines's Avatar
SouthwestAirlines is a diecast iconSouthwestAirlines is a diecast iconSouthwestAirlines is a diecast iconSouthwestAirlines is a diecast iconSouthwestAirlines is a diecast iconSouthwestAirlines is a diecast iconSouthwestAirlines is a diecast iconSouthwestAirlines is a diecast iconSouthwestAirlines is a diecast iconSouthwestAirlines is a diecast iconSouthwestAirlines is a diecast icon
I recommend balsa because it's basicly cardstock but looks a ton better. Good luck with this, I look forward to seeing progress pics.
Brookefield International
KSTL East Terminal
La Tierra Del Sol Aeropuerto Internacional
Frank Luke Jr. International
SouthwestAirlines is offline   Reply With Quote
Old 04-18-2010, 01:22 PM   #4
sba757 was here too :)
Kris Air's Avatar
Kris Air is a top dogKris Air is a top dogKris Air is a top dogKris Air is a top dogKris Air is a top dogKris Air is a top dogKris Air is a top dogKris Air is a top dogKris Air is a top dogKris Air is a top dogKris Air is a top dog
Thats a hefty job you got their I recomend is miny bricks for the inner than cover in balsa or use aricutectual design material!!
sba757 was here =D
Kris Air is offline   Reply With Quote
Old 04-18-2010, 07:53 PM   #5
alabatusa's Avatar
@ Peak Airways, I just want to use plywood as a base(table) for the airport, not for any modelling as such. However the MDF looks good now aswell. I just need some guidance, on the thickness I should use for my table, such that it will be able to support the wieght of my model. For the construction of my terminal I will most likely be using balsa wood, some clear perspex or transparent sheets for windows.
@Kris Air, I don't fully understand what you mean, whats the inner. And what are miny bricks, never heard of them before.
Thanks Guys much appreciated your input
Old 04-18-2010, 09:10 PM   #6
Yeah, I was talking about the base. I was referring to the "ground" of your airport. When you want to do the ground markings you'll either want to paint or adhere some sort of "foil" to it. Plywood is kind of lousy for that. Good luck!
Old 04-18-2010, 09:56 PM   #7
alabatusa's Avatar
Ok thanks Peak Airways (whats your real name btw), I will use MDF then, im going to be using custom made* foils.
Old 04-19-2010, 07:45 AM   #8
alabatusa's Avatar
Here is a short video of my back terminal , and a few photo's of some supplies i've stockpiled so far. Sorry for bad quality, its all of my iphone
Old 04-19-2010, 08:47 AM   #9
alabatusa's Avatar
Currently in the process of making a google sketchup 3d model. Will post it up once i've made it.
Old 04-19-2010, 10:03 AM   #10
alabatusa's Avatar
Thumbs up Re: [project] Allama Iqbal International Airport - Lahore Model
Hi Guys,
This is a quick sketchup i did, its really rough and not my final version. Im going to create a high quality one later. This was just a 30min quickie. Just to see how hard it would be to work with balsa so far its quite simple, might have trouble with hexagonal peices.
any positive critisicm welcome.
Night got work tomorro morning zzzz.
Old 04-19-2010, 10:32 AM   #11
Good, I think you'll like the result better.
-Rich
Old 04-19-2010, 08:16 PM   #12
alabatusa's Avatar
sorry pics didnt upload properly earlier.
Old 04-20-2010, 01:49 AM   #13
Kris Air's Avatar
Inner as in the center and miny breks are tiny breaks with morter to build stuff which I use but the are kinda expensive! Oh it looks nice!!
sba757 was here =D
Old 04-20-2010, 01:54 AM   #14
alabatusa's Avatar
Price doesn't bother me, could you give me an example say with a picture, or where i could find some.
Thanks
Old 04-22-2010, 08:44 PM   #15
alabatusa's Avatar
Anyone know a good thickness for MDF? im gonna be drilling small holes in it to fit my LED's into it.
Thanks
- by stad31
- by sba757
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright ©2000 - 2012, Wings900.com
